I'm in the process of re-wiring my '65 F250 (automatic, 2WD) and am having trouble identifying the purpose of each of the 7 wires coming from the steering column. The wiring kit schematic, my Ford wiring schematic and the actual wires coming from the column (I installed a new turn signal switch but the wire colors on the original and on the new switch match) conflict.
Here is what comes from the column now and what I think the wire is for with color code # in parenthesis:
white/blue - front right hand turn (2)
green/white - front left hand turn (3)
blue/yellow - horn (1)
blue - flasher to switch (44)
green - rear right hand turn (282)
green/orange - rear left hand turn? - Ford schematic shows yellow/black (283)
orange/blue - only thing left is the brake switch - Ford schematic shows red/black (810)
I have done a Slick search and checked the web but haven't been able to come up with anything.
Also, I'm not crazy about the chintzy plug the wiring co supplied for the steering column. Can anyone suggest a nice plug with good positive contact for this purpose.
I have only pulled out half of my hair over this re-wiring job so I feel like I'm doing pretty good. Then again, I'm only half done so I could end up bald, I guess.
Julie
Steering column wiring
Re: Steering column wiring
your list is correct
the orange is the red\black power in from brake light switch
green\orange replaced yellow in later years
i have some original 65-66 ford plugs, you could possibly remove the wires\pins from the new plugs and use the factory ones
Brian's suggestion sounds like the way to go. You might want to purchase a pin removal/installation tool if you don't have one. I like WeatherPak type connectors for non-original applications; they are good enough for NASCAR and industrial applications. The downside is that it takes a rather expensive crimper/die set to do them well!
The Iceman is a guru to a lot of us Julie on some of the
mysteries that these old trucks have. He is my ''Go To'' on a lot
of issues too. Bet he can get you dialed in. TR
