Time for a trans rebuild?
ThinLizzy13
Post by ThinLizzy13 »
I opened up my trans (NP435) while it was out of my truck. Inside I found first gear to be worn on one side and third gear with a gouge right down the middle... Ideally I would like to take it apart and replace those gears, but it's not really in the cards right now.
Not sure how it would shift between gears before because the clutch was inop, but I could start it in gear and it seemed to hold the gears fine.
I'd be occasionally driving the truck just around town and probably not hauling anything. Since I have zero experience in what's acceptable inside a trans I figured I'd consult the slick "professionals." How bad does this actually look?
Better shot of first
If I can get away with putting this back in the truck and using it I'd like to. Then I would keep my ear to the ground for a used np435 in better condition/start looking for one. Those gears and rebuild kits sure are pricey...
Re: Time for a trans rebuild?
I wouldn't worry at all about first gear. Its non-synchronized and will almost always show some wear on the edge. I am not sure about the one with the gouges. I think there's a strong chance that it would be fine. Everything appears to be well lubed and clean and there are no sharp or protrudung edges.
BarnieTrk
Post by BarnieTrk »
I'd do a very thorough cleaning of the case, all the while looking for pieces of metal....
If nothing beyond dust is found, then I'd give the case a good flushing/rinsing out with diesel fuel, put it all back together and run it.
When comparing the NP435 to modern day transmissions, it is a BEAST. I wouldn't worry about those couple of dings in the teeth.
Just my :2cents:
BarnieTrk
:iagree:
Clean real good & new oil
Those are going to last a long time
ThinLizzy13
Thanks a lot slicksters, I feel much better about putting it back in. Ill give it a thorough flush and look it over again before I full it back up.
Don't want to beat a dead horse here on the topic of fluid, but the manual says SAE50 is recommended. I've seen on other forums and on Novak transmissions that 80w90 is suitable. Is that what you all run in yours?
BarnieTrk
Post by BarnieTrk »
ThinLizzy13 wrote:..... on the topic of fluid, but the manual says SAE50 is recommended. I've seen on other forums and on Novak transmissions that 80w90 is suitable. Is that what you all run in yours?
Yep.
The last time I changed my T-18 transmission gear lube, I added a quart of LUCAS Gear Lube...
http://lucasoil.com/products/gear-oil/g ... 0-gear-oil
...and then filled the box to the fill plug with my 80W-90 gear lube, put the plug in it, blocked a front tire & jacked up the rear-end to get the rear tires off the ground, started the engine, ran through all the forward gears and reverse gear, then turned off the engine, lowered the rear-end to make the truck level again, waited 10 minutes, then rechecked and topped off the transmission gear lube. I will likely check the lube level twice a year and change it again a few years from now....... :2cents:
BarnieTrk 8)
ThinLizzy13
Thanks BarnieTrk, that's exactly what I'm going to do :thumright:
Won't have to jack the truck up though cause the driveshaft
Is out :wink:
