Shop Compressor drain
jakdad
Post by jakdad »
What kind of set up do you folks have for your compressor drain? The way mine is now, I end up with water all over the shop floor. Thought I might run my drain through the wall to some kind of sump in the ground. Don't know how to go about it. Open to suggestions..................
Jim
that Houston humidity must be the source of all that water? i just let mine out on the floor as theres never more than a 1/2 cup or so of water.
jakdad
Post by jakdad »
oh no. We are talking buckets of water. I really need to drain more often but it creates such a mess.
Jim
Slick Fan
Post by Slick Fan »
I haven't tried this yet, but I read a good idea on another site a while back of putting a ball valve on the bottom, with a length of hose on the other end.
If you don't have a floor drain, you could probably put the other end of the hose in a bucket or something...maybe. Still has the potential to make a mess, I guess.
jakdad
Post by jakdad »
Thanks, I know a bucket wont work. I would end up with water all in the rafters and other stuff I have overhead :lol: . I have galvanized pipe comming out of it now with a valve. I may have to continue it through the wall. I'm not sure what to do once it's outside due to noise and blowing water/oil all over the back yard.
Jim
Slick Fan
Post by Slick Fan »
jakdad wrote:I'm not sure what to do once it's outside due to noise and blowing water/oil all over the back yard.
Yeah, I guess that could pose a problem.
ghostflamed66
Post by ghostflamed66 »
I put a 90 deg fitting on bottom of tank then ran a 8in pipe to a ball valve.
From ball valve i ran a pipe out the back wall of shop.
This setup has worked for 4 yrs.
Wes :D
64 4x4 with tilt front end
65 f100
66 f100
66 ranger
66 fairlane 500
36truck
Post by 36truck »
Seeing as you are in Texas and not likely to freeze. Why not run it outside into a hole dug into the ground filled with some clean washed rock. That way it can drain out and be arbored into the ground.
Tom Williams
jakdad
Post by jakdad »
Sounds like a good idea. What size hole? 2X2 X 2feet deep? Use about 12" of rock in the bottom? That should muffle the noise. Maybe 30" deep.
Here is the offending machine.
http://fordtruk.com/forums/album_showpa ... user_id=77
Jim
jwh f-100
Post by jwh f-100 »
At work we run it outside (points stright out). It has a ball valve on it and normally we just crack it open to drain just the water out then shut it when it starts blowing air and do not drain all of the air. When it is very humid I very slightly open it. It very slowly drains on its own. It is opened so slightly that it creates a "fog" out the drain but keeps the tank dry. Every so often it gets opened fully also. When the drain was not outdoors it was a pain in the neck.
36truck
Post by 36truck »
I can see why you have so much water. It pumps in all the hot air right into the tank. There is no cooling before it goes into the tank.
Make the hole big enough to hold all the water x3-5 times in order to let it soak into the ground.
Tom Williams
jakdad
Post by jakdad »
36truck wrote:I can see why you have so much water. It pumps in all the hot air right into the tank. There is no cooling before it goes into the tank.
The air going into the tank is probably over heated due to being a two stage pump. Maybe other pumps have a cooling cycle. Don't know how to go about doing that.
Jim
36truck
Post by 36truck »
That comes with old school compressor newer ones have a cooler on the side. I have a newer IR that has a cooler and auto drain.
Tom Williams
Fordman
Post by Fordman »
when i was akid my dad had a hotwater tank that was made intot a compressor. on the end of the tank as it layed onits side. he had a cock vavle like a radiator. and a piece of surgical tubing that ran out the door.. it was kind of short so when you opened the vavle the tubing who go all over the place like a firehose with no one holding onto it. it was kind of fun to play with once in a while i guess.
jakdad
Post by jakdad »
Another reason taht I have a lot of water is that my tank doesn't get drained often enough due to the mess on the floor.............. bang.gif
Jim
shawns fords
Post by shawns fords »
you could use it to water the lawn too lol.
this is the good side
Max
Post by Max »
Why don't you drain it into a plastic antifreeze container or windshield washer fluid container - something with a closed spout and just get in the habit of doing it regularly?
Mine is an upright and the drain is on the bottom. I drain it daily and have a big sponge underneath the valve that I let the water run into. Most of the time it's dry the next day when I drain it again. Summertime is more water.
jakdad
Post by jakdad »
I can't drain into anything like that. The tank is usually at least 150# pressure when it starts to drain. So I am getting air and water under pressure. I'll prolly put it through the wall into a ground sump.
Jim
Max
Post by Max »
I gotcha. What about something like this: http://www.paragoncode.com/shop/compressor/
Possibly in addition to running that line outside.
jakdad
Post by jakdad »
Nice kit. I may look into that as we have a Harbor Freight in Houston.
Jim
