Diffrences in 65 and 66 f-100's
So my title says its a 66 but from what ive seen the grill is 65. Im not sure if someone just put on a 65 grill. So i dont know what year it is. Is there anything else that sets the 2 years apart from eachother?
Its not hard its just really really fast.
I have a Ford f-100 65' long bed 352 FE
- 6166 Junkyard Dog
check vin number lasy 6 numbers will tell you that, side emblems are different 65 says Ford F-100 across the top of it, 66 say Ford acroos the top only with either 100 or 250 in the bottom lettering,, 65 park light lens has a ground wire where 66 does not, 66 core support look on pass side behind grill you should see 3 cage nuts sticking through holding battery tray, where 65 will not have those 3 cage nuts, 66 radiator mounts flush to support where 65 has a flangethat brings rad towards motor, inner fenders look at bottom by support, 66 just hangs there, where 65 mounts to the bottom of the support for extra support of the inner fenders,, look at the drivers side frame rail right behind where support is should be a number stamped from Ford starting with C6TA Right above where a slot is to put a safety chain, lets see don't believe I missed anything else,
some firewall stampings have seen different between 65 and 66 really need the 2 trucks next to each other to see it, now all this is for 2 wheel trucks
Kathy
Now Cooper will try his best
The easiest way I use to at least get me in the ballpark is by looking at the gas pedal. If it's bolted to the floor, it's '65 or earlier. If it's suspended from above, it's a '66.
Although, I think it's possible that a very late '65 could have a suspended pedal, but for sure all 66's have it, as far as I know.
- Johnny Canuck
- 6166 Junkyard Dog
I started to say that but was not 100% sure
Kathy
Ah, see? That's how much I know.
- Johnny Canuck
"A 66 is one year newer than a 65."
Somewhere along the way, the tailgate latch access plate (from the inside) changed as well. Its possible that this detail was a 64-65 thing though (remember the styleside bed arrived in 64.) I just know that my current tailgate is different than one of my other tailgates.....
CC 66 got different rims and larger hubcaps.
- 65 66 Ford
66Gobbler wrote:I always looked for the indentation in the middle of the roof. Thought that was a 66 model year only feature.
64 65 & 66 all had that. The roof was also about 1" taller on them.
Right, I forgot all about the door tags.
Here's two of mine. '65 on top & a painted over '66 on bottom.
If the VIN on the title & VIN on your tag matches the VIN stamped on the frame, then you've definitely got it nailed down.
Well all 3 should match, Door Tag + Frame + Title.Slick Fan wrote:Right, I forgot all about the door tags.
http://onfinite.com/libraries/869370/da3.jpg
http://onfinite.com/libraries/1405647/287.jpg
If the VIN on the title & VIN on your tag matches the VIN stamped on the frame, then you've definitely got it nailed down.![]()
http://onfinite.com/libraries/1409574/add.jpg
In KS you don't have to have the door tag it is not a "VIN Tag" only a "Warenty Tag"
But check with your local DMV.
